Results 1 to 10 of 12
Thread: Main Muffler removal??
    Wilbz Guest
    I've been told if I remove the main muffler out of the exhaust system of my '99 Td5 manual Disco, I may gain a little more power down low / off the mark.
    Is there any truth to this? Would I be wise to remove the muffler?
    Cheers..
    Padstow NSW
    Quote Originally Posted by Wilbz View Post
    I've been told if I remove the main muffler out of the exhaust system of my '99 Td5 manual Disco, I may gain a little more power down low / off the mark.turbo is quicker to spool up
    Is there any truth to this? yes Would I be wise to remove the muffler? yes
    Cheers..phil
    ....search is your friend
    Nov 2008
    yes an no,,
    it lets the gases flow faster an smother out the back, witch intern lets the turbo spool faster, witch gives you beter down low, but you will only realy notic this on a manual,
    but the main reson is that it sounds meaner
    Wilbz Guest
    Sweet.. I just had the muffler removed and... does have a slightly better note to the exhaust, but definately better acceleration. Recommended mod..
    Thanks for the replies...
    Cheers..
    Nov 2008
    Cheers..
    wate till you here a 3" straight Thu mate, now that sounds unreal, the turbo wissel is like OMG
    cant wate for mine to have it done
    Adelaide Hills - SA
    Cheers..
    That was quick!
    You don't muck around - all done by 11:00Am!!
    Wilbz Guest
    Yeah no mucking around.. I had planned on doing it a while ago, but wasn't sure whether to do it or not. I had all the gear and bit the bullet.. Glad I did now...
    Adelaide Hills - SA
    Have you got your own pipe bending gear?
    How did you make the flanges, or did you just buy them and weld them on?
    Wilbz Guest
    I had an old muffler that was knackered, so I cut the old flanges off that and used them. As for the pipe itself I had it bent up some months ago.
    Quote Originally Posted by stig0000 View Post
    yes an no,,
    well I dont own a TD5 but if the td5 is anything like the 300 with the muffler removed you WILL notice it in an Auto I certainly did my car is very quick or the line as the turbo spools up so much quicker
