I had issues with my scissor one so off I went to bunnings and bought a length of ali tube I think 20mm and a pack of u shaped spring clips (zennith brand, a bit rubbish but ok). Flattened out the top and drilled a hole to fit the existing pin, cut the tube to max lenght and attached the sping clip to the existing bracket that is welded to the bonnet frame. see pictures, if they appear as its my first atempt.
Mal
http://www.aulro.com/afvb/attachment...&d=1251693191e
