                                                31st August 2009, 05:23 PM
			New 110 test drive
					Just got hold of a new 110 for an over night test run.It drives pretty good,has enough get up and go and is really comfy to drive.The air con and heater work very well.Its parked in my driveway I have just about pulled it to bits checking it out.Although its a long time since I have had a good look at one, things I have noticed are there doesnt seem to be drain plug in the clutch housing, just a weep hole and the door seals are a bit rough,especially the bottom ones where you can see daylight past them and they are permanently creased in spots.Will leak for sure and into the electrics under the drivers seat.But I am still keen on owning one.Cant see where I can fit a second battery.Can anyone help me with that one.I'm sure if I can get a good deal the 110 will soon be in the driveway with me trying to fit it out for trips away.
                                                31st August 2009, 06:36 PM
					After 20000 km and 12 months  I'm enjoying mine very much..she has improved with age.
 The dual battery setup is on my list of to do's. I'm sure that there is room under the pasengers seat for two batteries...maybe not two of the same size as the original.
                                                31st August 2009, 11:09 PM
					Make tracks in Midland W.A modified ARB system to fit under passengers seat
 Allan
