Hello Sit,
Prototype for the 'Puma-TdCi' Ex-Box is finished. We will discuss it this Friday if all good we go into production mode.
Should hopefully be ready for the LR Clubs' Expo end of September.
The Ex-Box is not a replacement for the standard LR Cubby Box. It's intention is to provide space for all the electronic gear which normally sits under the drivers' seat.
The standard LR Cubby Box is then bolted onto the Ex-Box.
For a late Td5 model the Ex-Box is pretty much full once you transferred all the gear. For the TdCi model you will have additional space to put your own gear in (eg radio).
In regards to the size. The TdCi Ex-Box has the same width as the Cubby Box, it is about 50mm longer than the CB and the height is roughly 150mm. The main differences to the standard Ex-Box are: 1) the front section is at a slight slope to give room for the differential lever and 2) the rear section finishes further back.
Trust to see you be at the Land Rover Clubs' Expo.
Daniel
