                                                2nd September 2009, 01:32 PM
			Defender Front Coil Spacers
					Hi all,
 Just wondering if anyone has fitted these and how hard it was to fit.
 Also where did you buy them from and how much. Pictures would also be a great help.
 Jordan
                                                7th September 2009, 07:43 PM
					Hey mate.  I'm running 30mm spacers in the front of mine....  Mainly just to even it with the back as the winch and bar dropped it down a little....
 Really easy to fit,
 Undo your shocks..
 I jacked up the 4x4..  removed the tyre and then had another jack holding the body...  Let down the jack that is holding you diff untill the spring becomes loose...  Slip the spacer in and put it all back together
 Think both side took about 30mins..
 I got them from a place in brissie, but they have closed down now...  You can get them on ebay..  just do a search for "coil spacers"..   Probably around $40 from memory..
