How? haha
I went out and bought bearing pullers which were cheap as, thinking it'd do the trick but as it turns out I was wrong, the teeth don't fit into the groove.
So what are my other options? I dont want to buy the LR tool because it will cost me a small fortune. Help!
Regards,
Matt
Just having a look at some pullers that I think may do the trick:
https://www.alltools.com.au/shop/ind..._Separator_Kit
Bloody expensive
I used a steady hand and an angle grinder.
Matt,
Thats the one I have, but with the extras and the hydraulic ram was closer to $400.
Can you borrow one from someone for the job? Or, $179 isn't too bad and you may need it again for something else...you DO own a Landy
JC
I like the angle grinder idea haha, but where do you grind through it? If you cut around the groove, itll just leave half inside the box?
Location? There are a number of places that you can visit to do the job. I have the bearing plate separator, but it''s no good to you if you're not in SEQ.
Im in Perth ahah
No biggie.. any decent mechanic should have the gear - if you haven't already found this thread, the first photo should help describe what JC was saying.
Using a V8 R380 in a Tdi
I live just 20km from Tank, so that when I had to remove mine, I was able to use his puller.
It was like the one in your link complete with a hydraulic ram. It was rated as a 10 tonne puller and it only just did the job.
So there is another advantage of living on the glorious South Coast of NSW.![]()
