Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: RED 130's Suspension Change
    Logan Village area S.E. QLD
    We have finally redone the suspension on the fender
    we have taken the inner spring out and fitted Firestone Airbags inside the outer spring..
    I went for a drive and it is definitely softer on the road.....didn't even notice the speed bumps in the car park..... with no load in the back..
    we will put the camper on shortly and see if the desired effect will be achieved....which is less bum sag and less body roll
    Mrs ho har
    Series Landy Rescue
    Our FB Page..
    Jan 2008
    Brisvegas
    Quote Originally Posted by The ho har's View Post
    Mrs ho har
    ..............................MUST................ .........................RESIST................... .................................................. .................................................. .................................................. .................................................. .................to much temptation........................................ .................................................. .................................................. .......................................
    CC
    Adelaide - Torrens Park
    Mrs ho har
    You know the correct technique is to inflate the airbags prior to loading the suspension. The alternative is to use a jack to regain the correct ride height and then inflate the airbags.
    They are not designed to lift the loaded vehicle back up to the correct height.
    Quote Originally Posted by Col.Coleman View Post
    CC
    and you do know I am talking about RED soooo behave
    Mrs ho har
    Series Landy Rescue
    Our FB Page..
    Quote Originally Posted by BigJon View Post
    Yep that is correct....
    Mrs ho har
    Series Landy Rescue
    Our FB Page..
    South East Tasmania
    and less body roll
    Mrs ho har
    Pardon my spanglish but, when on the road?
    yes Arthur ...body roll on the road.....and when parked
    Mrs ho har
    Series Landy Rescue
    Our FB Page..
    Torres Straits
    Morning Mrs Ho har,
    Did you replace the main coils to a heavier rate for your new system?
    I will be interested to see how you go, but my experience with a few coilers and poly airs is they wont support anywhere near the mass of the inner helper spring (140lb/in from memory).
    Measurements and tare / gross weights would be good info!!!
    Steve
    Feb 2005
    what happen if you load up first than inflate
    i never worried as during normal offroading you are either loading up or unloading one spring all the time
    May 2006
    Carlton, Melbourne
    Mrs Ho Har,
    Let me know what you think, as we've just bought a camper for our 130, and I'd like to hear if they improve the handling/ride height.
    Ta,
    Fraser
