Thread: Help needed please.
    Jul 2008
    Help needed please.
    While poking around the engine bay on my td5 130 deefer. I came across this sensor. It is located below the turbo on the left handside of the motor. It looks like it has been played with by the previous owner. The blue wire has been cut. What is this sensor for and should it be replaced. Thanks in adance
    Jul 2008
    Had a problem with the photos I hope all is good now.
    Kingston, Tassie, OZ.
    Dave,
    That is the oil pressure warning lamp switch, it only has one wire, there is actually 2 in the plug originally, but if you disconnect the plug and look in to the switch, there is only 1 terminal
    The wire that has been removed is redundant.
    JC
    Jul 2008
    Thanks JC
    One less item to be concerned about.
    johnclv Guest
    Yep
    All you need to be worried about now is the part called a TD5
    when you have that one sorted you have to worry about the other part - Landrover
