Thread: clutch replacement at home
    Feb 2005
    hey guys
    a mate of mine is about to replace the clutch on his 300tdi at home
    any tips prior to starting that might make the job a bit easier, at this stage he will remove the transmission/t-case, he has jack stands, trolley jacks etc
    Q - clutch kit? which is best
    Q - clutch aligning tool
    anything else he should look at while the box is out
    JDNSW's Avatar
    hey guys
    Can't comment on what clutch kit, as I haven't done that model. Clutch aligning tool - simplest is to make one - note they can be made of wood, all you need is a wood lathe, measure the diameter of the inside of the splines in the plate and the diameter of the pilot bush.
    Expect to replace the pilot bush and have a very good look at the throwout fork - either replace or reinforce it or both. Check for oil leaks from gearbox and engine.
    Feb 2005
    he has access to a machine shop so i'm sure he could knock one up
    Jan 2008
    Gladstone, Queensland
    I made an alignment tool from a long reach socket that fitted the flywheel bush snugly and then wrapped insulation tape around it where the clutch needed to be until it was snug too. Worked a treat, cost next to nothing and took all of 2 minutes to produce.
    I have a couple of input shafts, hes welcome to borrow one of mine.
    A couple of dowel bolts to help with sliding it out and back will be a godsend.
    I usually cheat abit and find a 3/8th socket that fits into the spigot, put a 1/2 inch socket in the friction plat and then slide a 3/8th extention bar through the 1/2inch socket and fit it into the 3/8th socket in the spigot.
    Im also a big fan of a padded block of wood across the wings to help support the back of the engine at the exact position you want it in with a safety rope to the top of the bell housing.
    also IMHO 3 blokes is the best number of people to mandraulic the box out, one to stabalise the bell housing, one to stabalise the tcase side and one to co-ordinate/drive the jack. (not such a big deal if you have a proper trans jack.
    when it comes time to assemble put a 12 inch long section of 3/4 inch hose over the clutch pushrod and poke it through the clutch slave hole.
    Eidsvold QLD
    cant wait for the tutorial!
    The Ugly Duckling-
    03 Defender Xtreme, now reduced by 30%.
    a master of invisibleness.
    Qld.
    Yeah! Can we watch?
    2007 Defender 110
    1993 BMW R100LT
    Perth W.A.
    i think a step by step picture session is in order that would be helpful to many !!!
    good luck
    Dags Guest
    Quote Originally Posted by lardy View Post
    good luck
    I'll see what I come up with...
    Jul 2011
    Moscow
    Nothing?
