Results 1 to 8 of 8
Thread: Swap an LT77 for a R380
    Jun 2008
    Manning WA
    Can I swap my warn out LT77 gearbox for a R380 gearbox with not yo much trouble ? into a 1993 200tdi .
    Cheers Stewie
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    Quote Originally Posted by stew1236 View Post
    Cheers Stewie
    We did the same conversion on a 93 200tdi disco, it was pretty much a strate swap, you can run the same transfer, but make shore you swap the bell housing (don't try use the lt77 one on the r380, we found out the hard way)
    It would probably be different on a defer though, so can't say for shore
    TIM.
    Adelaide - Torrens Park
    I believe on a Defender it is near impossible...
    Oct 2007
    Quote Originally Posted by BigJon View Post
    Well in that case Stew, forget my post
    I was under the impression from a friend who tried to get hold of one for us it was a bell housing swap...its just the bell housing is hard to get hold of for the 200tdi
    clean32 is offline AULRO Holiday Reward Points Winner!
    SA, Newton
    bell housing, shifter links, cut weld etc.
    Jun 2008
    Manning WA
    Thanks Guys , I will revert to plan A , and recondition the LT77 .
    Once again thanks Stew
    i looked into this while back ashcroft transmissions did make a shorter input shaft an i think i need to use a lt85 bellhouseing then it all bolts up
