Results 1 to 6 of 6
Thread: Auto Trans Fluid Change Disco 2
    KevI Guest
    Requesting tips and advice on renewing auto transmission fluid 2002 TD5 Disco 2.
    Geelong, VIC
    Haven't done a D2, but essentially the same box as a D1 except with electronic control.
    If you want to give it a proper birthday you will need to remove the sump to change the filter. On a D1 this involves removing one of the transmission mounts to get access to the rear sump bolt - again not sure if its the same on a D2.
    I'm not sure if the correct terminology for the bit on the bottom of the trans that holds the oil is sump or pan - but I'll call it a sump.
    Drain the oil
    Remove the sump (6 bolts/clamps)
    Remove the filter and pickup from the valve body - 3 bolts ( Torx T25 from memory )
    Remove the plastic pickup
    Fit new "O" ring to pickup
    Fit pickup to new filter
    Fit new "O" ring around the hole in the filter where it mates with the valve body
    Refit the filter and pickup to the valve body
    Clean the inside of the sump
    Refit the sump with new rubber gasket (normally comes in service kit)
    - not that there are 2 different clamp styles, one for corners of sump and one for straight sides of pan.
    Refill with correct oil and go through normal oil level check procedure.
    Note that you can only drain about half the oil as a lot is trapped in the torque converter etc. If you want to get closer to a full oil change then after the initial change, drive the vehicle for a few hundred k's and then drain and refill again. You should have around 75% fresh oil in it once you've finished.
    Steve
    Geelong, VIC
    If you want a good tutorial with pretty pics look here: DIFFLOCK - ZF Auto box Oil and Filter change
    Steve
    May 2009
    Tatura, Vic
    If you want to do a full change of oil this is how I do it.
    After dropping the pan and changing the filter, refit the pan and fill with oil. Before starting engine remove the return line from the oil cooler. Put a hose over the end of the pipe and place end in a container.
    Start engine and top up trans whilst it is pumping out the old oil from the converter. As the oil going through the convertor goes directly to the cooler you are changing the oil in the converter.
    Dave.
    May 2003
    On The Road
    Geelong, VIC
    Well stuff me - I looked in "The Good Oil" but didn't see that one.
    Maybe I need to go to bed earlier....
    Steve
