Results 1 to 10 of 18
Thread: Oil in 300Tdi intake
    SW of Geelong
    I have noticed an oily residue inside the intake pipes, post turbo on my 300Tdi. The turbo is a brand new Garrett, about 2000km, so shouldn't be a problem there, but not completely ruling it out though.
    What other possible causes should I be looking for ? Is there some sort of problem known with the 300Tdi that might cause this ? I haven't owned it long enough yet to be familiar with the 300Tdi, so any help would be appreciated.
    Cheers, Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    Geelong, VIC
    If its the same setup as the 300tdi in a Disco, then the crankcase breather goes into the intake duct between the air filter and the turbo inlet so you can end up with a bit of oil that way.
    Steve
    Jul 2007
    Quote Originally Posted by steveG View Post
    Steve
    x2 what he said
    Fairly ordinary oil catcher, therfore always sucking in oil vapours. Reduces efficiency of cooler
    Nanny state UK...
    TBH - It is not uncommon on the 300TDi to get an oil residue on the inlet side of things. As such, cleaning out the intercooler is a regular service task.
    As for what causes it...
    • Rocker cover breather... Need to clean out the canister.
    • Turbo charger.
    • EGR (if still fitted...)
    HTH
    M
    SW of Geelong
    So, has anyone disconnected the crankcase breather return pipe from the intake and vented it to the atmosphere ? Is there any problem in doing this, apart from (more) oil dripping on the garage floor. It just seems wrong having all that black crap in the intake and intercooler.
    Murray
    '56 SI Ute Cab
    sydney
    i tried with a boy racer oil separator thing but its made things worse as the pipe was too small, howevre am running 200tdi and that breathes real heavy ie oil drips out of air filter, tried claening repalcinbg most things so now just liv ewith it
    Nanny state UK...
    Quote Originally Posted by rijidij View Post
    Just live with it, it's not doing any real harm...
    You're going to do more harm by letting it vent into the atmosphere. Not only are you going to be letting the oil fumes out but you're going to run the risk of letting water/moisture and other stuff in.
    M
    WA
    Contrary to the above posts, it IS doing real harm. Oil laden with soot is well known for killing turbochargers in heavy diesels. That is why all of them have crankcase filters these days. A bunch of people on here have Provent crankcase filters for their 300Tdis. Most have not yet fitted them though
    Such filters will remove 90+% of the oil before it can get to your intercooler or turbo.
    May 2002
    Heathcote (in "The Shire")
    And I didn't put my hand up for one because I would only be doing about 10000km (or less) per year, but at least it would have been fitted.
    Martyn
    NE Victoria
    32.83 MB
    Quote Originally Posted by Bushie View Post
    Martyn
    X2
    Tony
