Thread: Good earthing point in rear of a D2
    Nov 2007
    Looks like a few Disco owners have opted to but their aux battery in the rear... I'm looking to do the same but have a question....
    Is there a good earthing point back there or would any solid chasis connection do??
    Cheers.....
    New :- D3 TDV6 2006 SE
    Bullbar, traxide dual battery
    General grabber ATs
    Mitch hitch
    Home made drawer and fridge system
    Foldable UHF antenna on roof rail
    Gosnells WA
    Any chassis connection will be fine as long as the area was cleaned of paint, rust, oil etc.
    Perhaps paint over the top of the connection when done to prevent rust.
    Ben
    Ben.
    Team W4 - WEBSITE
    Melbourne, AU
    More reliable is to run a dedicated earth from the engine bay either from main battery or controller depending on your set up. you are going to be running the positive cable anyway.
    _________________________
    1996 D1 V8 - gone
    2002 D2 Td5 ES- gone but still running elsewhere
    2013 D4 SDV6 HSE - gone
    2023 Defender 110SE D300
    99.87 MB
    I run to the chassis, but I understand the d2 chassis is only incidentally earthed - so it's not a very good way to do it. The best option is the run the earth back to the main battery, otherwise I understand the body is where the earths all return from - not the chassis. If you do want to use the chassis, then make sure you also earth the chassis back to the battery at the front also.
    Slunnie
    Aug 2009
    Brookfield Melb. Victoria Australia
    Hi I used the lower LH seat belt bolt for my earth and everything seems to be working , Getting the right rate of charge to the aux battery and managed to hide most of the wires under the seat and carpet.
    Just have to be a little careful when folding the seat so as not to catch the wire,
    Andrew
    Dec 2008
    If the seatbelt thing doesn't work just drill a very small hole in the floor and use a self tapper to secure it. I had to do this as I found the seatbelt mounts in mine to be an unreliable earth.
    streaky Guest
    I'm not sure about DII's but in the rear corners of the DI floor there are earthing studs screwed into the floor. If you ever lift the carpet take a look and take note.
    S.
