Results 1 to 10 of 24
Thread: 4.6 Oil Pump ?
    Jul 2007
    Blue Mountains NSW
    4.6 Oil Pump ?
    My 4.6, Since We did it up a couple of years ago has had low oil pressure at idle, The light comes on sitting at lights etc, you give it a rev or hold the rev's up and the light goes out !
    I know the oil pump is in the timing cover with odd looking gears and a spring from memory but that's as far as my knowledge goes
    I have the Engine out at them moment and I think it might be a good time to overhaul or fix this problem ??
    Can anyone tell me what needs to be done ? Can you buy a kit ? What fails in there ? Is there a pressure release valve ?
    Cheers and thanks in Advance !
    Jeremy
    The pressure relief valve is in the cover near the oil pressure switch.
    The pump is non-serviceable. You have to buy a new timing cover and pump.
    Late edit: June 2011. The pump is now available as a service item. See later in this thread.
    Avoca Beach
    Quote Originally Posted by Jezzaol View Post
    Jeremy
    First question is are you sure your oil pressure is actually low at idle or whether the oil light switch is faulty. Have you checked the pressure with a mechanical gauge???
    I have rebuilt an engine with low pressure only to have the light come on in the rebuilt engine. Fix was a switch which is much cheaper.
    Regards Philip A
    Kingston, Tassie, OZ.
    Regards Philip A
    As above, try a mechanical gauge first, if the oil pressure really was that low then a fair amount of tappet rattle will be evident. Also, the oil lamp will usually take ages to go out when first starting if oil pump is badly worn, hot or cold.
    JC
    Jul 2007
    Blue Mountains NSW
    I have not checked the oil presure with a gauge but its does get a rattle if you leave it go for much more than a couple of mins !
    I gues I will check the pressure relief valve?
    Jeremy
    have had a Td5 with this fault, had manufacturing swarf from ally block brace and oil pick up assembly stuck in the relief valve plunger
    Easy fix and caught it before any damage was caused luckily.
    JC
    Jul 2007
    Blue Mountains NSW
    Is it a matter of replacing the Relief valve or ??? What should I check or clean ??
    JC
    Hi Jeremy,
    Just remove the plunger and carefully inspect the bore for scoring and evidence of the plunger not seating at it's base, IE at rest it should be able to seal off the chamber completely, and the springs actual tension holding the plunger down is what gives you oil pressure. If the spring is weak or broken, the plunger sticking and not seating that will allow oil to bleed off around it and therefore low oil pressure.
    If all looks OK, then I would be dropping the timing cover and checking the pump for scoring and wear on the thrust plate.
    JC
    Also check the teeth on the gears. They can chew out quite badly.
    On reassembly, Loctite the pump screws.
    May 2008
    Romsey, Victoria,
    Replacing the oil pump
    Ron,
    You can replace just the oil pump.
    OPK003 Kit O/Pump Repair V8 integ. Cost 58.10 pounds including postage.
    Just got one of these from the UK. Qualitypart is the seller on Flea-Bay.
    OIL PUMP GEAR KIT FOR ROVER V8 ENGINE FITS VEHICLES WITH AN INTEGRAL OIL PUMP FITTED IN FRONT COVER - SERPENTINE ENGINE CIRCA 1994 ON
    DEFENDER APPROX 1994 ON
    DISCOVERY II
    RANGE ROVER APPROX 1994 ON
    MORGAN WITH SERPENTINE V8 ENGINE
    TVR WITH SERPENTINE V8 ENGINE
    THESE GEARS ARE SUITABLE FOR THE ENGINES WHICH HAVE THE INTEGRAL OIL PUMP FITTED IN THE FRONT COVER. NORMALY FOUND IN ENGINES FROM 1994 ON.
    WE KEEP THE EARLY STYLE KITS AS WELL.
    Note there are 3 types of oil pump fitted to the Rover V8 Engines. We carry all three types of replacement gear kits.
    www.shop4autoparts.net
    No need to go the entire front cover, unless it is chewed out.
    On mine the outer ring of the oil pump gear split............
    Jeff
