Results 1 to 10 of 35
Thread: 302 powered Series 3??
    Perth - WA
    Just wondering if a 302 would reasonably fit into a series 3? Maybe someone has done this? if so what mods were needed and what gearbox etc would suit?
    Jim
    Yea, Victoria, Australia
    Jimmy
    Sure anything will fit, if you have the will and desire to complete it. As for how easy it is thats another question.
    If the base vehicle was a stage 1 then it would be relevantly straight forward as the rover v8 sits nicely in the chassis and uses the stronger fulltime 4x4 rangie gearbox.
    If yours isnt from that platform then you would need to:
    * Seriously beef up the Series gearbox or replace with the Stage 1 unit.
    * Most likely fit defender front end panels to house the radiator.
    * Make custom engine mounts.
    A windsor 302 would be a better pick over the cleveland as I think the deck height is smaller and therefore the engine is a little more compact.
    I think for all the screwing around it would cause I would buy a Stage one or better still a 110 V8. Thats what I did!
    Rich
    WA
    LandyAndy on here has a SIII with a similar conversion. IRC there is someone in WA who makes/made adaptors to mate ford boxes to the Series T-case.
    A V8 will eat series boxes for breakfast, but the T-case and the Salisbury (LW rear diff can handle a V8 with no issues.
    Sep 2004
    This one had a worked 351 in it.. top loader gearbox, stock transfer and running Nissan GU diffs
    Camo
    2004 Black Range Rover L322 Diesel
    Perth - WA
    Quote Originally Posted by dickyjoe View Post
    Jimmy
    Rich
    hmmm...cheers for that. the series 3 has a rover 6 in it and I already have the Windsor 302 in a pile of bits. Something for me to think about.
    WA
    Quote Originally Posted by Camo View Post
    Camo
    That's not Glen Zipf's SIII is it???
    SA, Newton
    earlier this year there was a white one with a 302 for sale in tasy
    Sep 2004
    Yep
    Was a beast
    Wish I had a drive of it
    Perth - WA
    that's sounds like it could be a cheaper option. Afterall i'm not looking to climb a sheer cliff, just cruise about. I want it to look original except the power plant.
    ta.
    Mareeba
    If you've got the 302 then I reckon hunt down a c4 conversion (marks). Strong enough for the grunt and work real well. Either series landy or range rover transfer case are available.
