Results 1 to 3 of 3
Thread: Help identifying PS box tapered thread size
    Adelaide, SA
    Anyone know the thread size for the high pressure hose on a 4 bolt power steering box (pic below)?
    The internal diameter of the threaded hole is 12.2mm at the bottom, and 12.25mm at the top. I couldn't find it in the workshop manual and all the references I've found on BSPT and NPT standards refer to external diameters
    The 3 bolt box thread is signifncantly smaller.
    Padstow NSW
    it wont be tapered as the pipe seals in the housing using an o ring. im going down to work in a min i'll measure the 4 bolt box i have there.
    cheers phil
    Padstow NSW
    M14 x 1.5
    cheers phil
