Hi Elvin,
You winch looks like it is an Aeroparts AEH.D type.
Does you winch mounting plate have a fold at the rear? If so, it is likely that you have the mounting plate for a Series 1 88"/109" setup. Can you measure the front to back distance of your plate?
What length is your driveshaft?
When the wheelbase was increased that model Series 1 had its front crossmember also further forward compared to the 80" and the 86"/107", so presumable had a longer driveshaft for the winch.
Driveshaft length for an 80" and 86"/107" Series 1 is 200mm.
The plate for a Series 2/2A should be very close to 330mm fold to front and there should be about 25mm from the fold to the rear face of the winch aluminium body.
I have checked these measurements for you on a 2A winch still mounted on a bumper bar. I have two drilled for capstan winch bumper bars here, also a 2A driveshaft and a spare 2A mounting plate (it's pitted underneath) - that could be your solution.
I will have to measure the 2A driveshaft later as it is at a friend's factory.
What would the normal clearance be at the driving plate when disengaged?- about 3mm.
What is the length of your winch driveshaft? - Will measure an original 2A in the next day or so.
What is the distance between the front crossmemeber and the inside edge of your bumper bar? - As I said the winch I have here is mounted on a bumper bar but not to a vehicle. The distance from the front edge of the bumper bar to the front edge of the winch mounting plate is 35mm.
The mounting plate bolts directly to the rivnuts fitted to the front crossmember on a 2/2A. Series 1 at first had tubes fitted through the chassis so the plate stands off the chassis about 6-8mm. Later Series 1s used rivnuts.
You should be able to work it out from those measurements.
What is the width and height of your winch mounting plate (looking from the top)? - Width (side to side of plate) - 450 mm, front to rear close to 330mm.
What is the typical distance between the top of the bollard and the grille? - There is clearance for the rope between the bollard and the grille.
How much end play in the drive should there be for these "plungers" to work? Are they needed? What do they do (reduce vibration when the winch is not in use?) - Yes, you need them as they act as an axle and centralise the drive shaft so it will not bind.
Hope this clears up a few things for you. We might be able to do a bit of swapping components!
Regards,
Bob
					 Aeroparts Winch Fitting
