28th October 2009, 08:53 PM
range rover sub l322
hi guys
i am getting a lot of background noise from my stereo system,almost like static.I opened the boot left hand compartment,thinking the sub would be in there...nothing.
Is it somewhere else? also the pixalation on the radio head unit has almost disappered,is there somewhere it can be repaired.
cheers.
paul.
14th December 2009, 12:18 PM
I think only the Vogue spec cars have a sub, if yours has the standard radio rather than the nav screen in the dash then chances are it wont have all the extra speakers either.
If it does have the sub then it's not in the left hand compartment itself, rather behind the trim panel further back. You can see the corner of the plastic enclosure with the 2 subs built in wth the access hatch open but it's set further back towards the wheel arch and you have to take all the trim from the side of the boot out to get at it.
