Originally Posted by
Pedro_The_Swift
There are 4 outlets on the ABS Mod and two solenoids,, one solenoid controls the Front Pass and Rear Drivers and so on,,
Hey Pedro,
Have a look at the ABS modulator schematic in the WSM on RAVE at page 70-13. You'll see there are 8 solenoids, 1 inlet and 1 outlet per wheel. Whilst there is 1 pump motor, there are 2 pump pistons, 1 for the front and 1 for the rear.
I think its purely a coincidence that you have problems with diagonal wheels and probably very lucky not that they're not on the same side, as you could be in strife if ABS kicked-in on 1 side only.
