Originally Posted by
rmp
I am reliably informed that LRs have better paintjobs that Japanese vehicles so it is easier for the pros to work their magic on them.
Not been my experience. I find the paint on new vehicles to be both thin and soft. The clear coat is pretty much ineffective and polishes off quickly.
If the scratches are through the clear coat then polishing will not fix the problem, it will make it worse. Polishing will only be effective if the clear coat has been marked.
If the scratch is through the clear coat and even through the paint itself you can use the paint touch up kits like this stuff.
It usually comes with different coloured waxes that you can build up to make the scratch flush with the surface. Has the added benefit of sealing scratches to prevent corrosion too.
Alan
Alan
2005 Disco 2 HSE
1983 Series III Stage 1 V8
