Results 1 to 6 of 6
Thread: Disc brake rear to 86 County
    Is it possible to fit a complete flange to flange disc brake rear axle / diff assembly from a later 110 into a 1986 110?
    Is there an easier way to get a disc braked rear?
    Tell ya in a couple of weeks.
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    you need to change the proportioning valve as well i belive...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Gilderoy, Victoria
    I think it's best to use the master cyl and booster from the later 110 as well.
    Mick
    1999 Land Rover 110 Defender TD5 Cab Chassis
    1985 Land Rover 110 County 4.6 EFI V8
    1993 Track Trailer camper
    Mandurah. W.A.
    I have fitted a complete diff (disc to disc) from a '94 Defender using the original booster and m/cylinder from the County. I actually bought the later model booster/master cylinder as well and they are still sitting in the shed. Did the conversion about 4 years ago, no problems and obviously much better with discs all round.
    Maggsie
    04 V8 Disco
    85 V8 County
    Freestyler Guest
    All you need is 110 front hubs, rear range rover discs and capilpers, and the mounting brackets off a defender. Aparrently you need to remove 3 mm of one side of the brackets? not sure which side. I bought a county wreck that had already had the conversion and maxi drive rear diff lock. One day I'll get around to putting it in along with the PTO Winch.
    Tim
