Thread: Stupid newbie question
    Aug 2009
    Hi
    Just had the 2000 Td5 manual on a rough dirt track going uphill slowly in 1st.
    Is the traction control light supposed to come on when it's working and does it make a noise when operating?
    Craig
    Ean Austral Guest
    Gday Craig,
    Yep the light will come on and you will definately hear it the noise is hard to explain tho..Wouldn't think TC would be needed in 1st gear, but depends on the track and tyres I guess
    Cheers Ean
    go give it the beans on a nice long flat smooth piece of gravel road and give the brakes the "stop, stop or we die you bugger" application
    the shudder and noise you hear coming from the brakes is the same one as the TC creates because it uses the same pump on the same parts to make the wheels do the Traction control magic
    as mentioned yes the light should come on and will stay on for a little while after the TC has eased off.
    Aug 2009
    Thanks Guys .... guess I worried a bit when I heard it AND then saw it. It seems odd that there should be a light on the dash when it IS working ....
    Sorry to waste your time .... I should have searched before posting. As always, plenty of info here on AULRO.
    C
    Ean Austral Guest
    Quote Originally Posted by Disco EMU View Post
    C
    Ahh atleast you know it works, always good to know after buying something 2nd hand as you did, I've had mine come on after going over a large pothole in the road,
    Cheers Ean
    Oct 2007
    newbie question
    TC makes a horrible noise,but that`s what it does.it`s the shuttle valves in the ABS modulator working.
    Good idea if you haven`t driven off-road for a while to drive over a few gutters or speed humps or whatever to exercise the valves.stops them sticking and causing the 3 amigos.
    If you don`t know them,you soon will.
    Trev.
    May 2003
    On The Road
    the passenger should also feel the pulses,,
    Ellendale Tasmania.
    Quote Originally Posted by trev View Post
    Trev.
    The 3 amigoes can be stopped, if you maintain the system on a regular basis, it's taken a while but i've got it sused now, change/flush the fluid, check and clean the conections of the sensors and work the TC on a regular basis.
    I have done this and my only encounter with the 3 amigoes was a dud/wrongly installed ABS sensor (on 3 occasions) which was a very long and frustrating time until I finally found out the problem myself and fixed it myself (I GO TO A DIFFERENT MECHANIC NOW) and the connection seperating under full articulation from time to time.
    It's amazing what you miss when looking for faults and trusting a well known Landy shop
    Craig the TC light doesn't always come on when the TC is working, but you will here it.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    May 2008
    Avonside NSW
    Trev.
    Funny you should say that Trev, Im a habitual kinda bloke and get fuel at the same place each week. I give her the berries out of the driveway to merge with the traffic invariably mount the gutter in the process and the TC light gets a workout.
    So good so see someone think they asking stupid questions. I dont feel lonely anymore
    Mat
    NSW SW Slopes
    Actually its the ABS pump hammering under pressure that makes the noise. The shuttle valves just operate switches.
