Results 1 to 10 of 14
Thread: Central locking posessed!
    Oct 2007
    Williamstown, Victoria
    Hello, just got myself a 2001 HSE 4.6 Rangie, it's awesome!
    Experiencing a weird problem though, the door locks are locking and unlocking on their own while driving, has anyone had this happen before?
    Thanks, Pete.
    May 2008
    Nice choice Pete - we need pics!!
    Someone had a similar problem here a while ago with their central locking... don't remember the solution... was something like dirty contacts perhaps?... do a search on this forum and/or over at rangerovers.net and you should get lucky.
    Cheers, Paul.
    Oct 2007
    Thanks Paul, yes I'm pretty stoked at the moment, just picked it up tonight it drives and runs like a dream.
    I'll post pics tomorrow!
    Cheers, Pete.
    Jul 2008
    Geelong Victoria
    Quote Originally Posted by PeterH View Post
    Thanks, Pete.
    Great choice of car! Remember the pics, tho!
    My 99 4.0 does exactly the same thing. Has done ever since we have had it. so if you find a solution, please let us know.
    As a temporary solution, we just lock the doors from the inside while driving. That shuts them up! And we never ever leave the keys in when we get out of the car!
    Willem
    Sep 2006
    Melb.
    I had a similar problem where the CL wouldn't unlock occaisionally. It was the Fuse box that was causing all my problems.
    Oct 2007
    I found the following on rangerovers.net:
    A related problem is when the doors randomly lock and unlock for no apparent reason. Nathan Bailey had this problem: "Most often it happens when the car is sitting in a parking lot or our driveway, but it has even occured when we are driving. If you lock the doors either with the remote or from inside the car with the button this stops the problem. The dealer thought it was a bad door lock, but was hesitant to replace one when they were not able to duplicate the problem while the car was in for one of its many service visits. The dealer finally figured out the issue -- it was the driver's side door latch. Once they replaced the item ($600.00 parts and labor, thankfully I purchased an extended warranty) the problem was solved. Since the latch has been replaced we have had no occurance of the issue."
    So I might go hunting there for a start, hopefully it does not require a new latch.
    Search the P38 forum on RR.net for door lock...there are several excellent references to this issue with lotza pics ... and some nifty DIY fixes
    Oct 2007
    Thumbs up Sorted!
    Ok, a good story for you here...
    Just got the vehicle, first day, went to start it and no joy, it just made that pathetic clicking noise as the starter tried to turn over.
    I was also getting weird error messages, lost traction, gear box fault, you could imagine my face, not happy Jan!
    It's hard with a brand new (to me) vehicle to even guess what the hell is going on...anyway my basic logic told me to start simple...check the battery.
    I worked out how to get the battery cover off and what do you know, the positive terminal is surrounded by a small mountain of that blue battery terminal corrosion.
    Cleaned both terminals up, tried to start, STILL no joy.
    OK, my 89 Range Rover just happens to be sitting right there, so I took the fairly new heavy duty battery out of that and swapped them over.
    Turned the key and it was purring like a kitten, very happy!
    Since then the door locks are behaving as they should and not an error message to be seen.
    P38 lesson number one completed!
    I'm glad that's all it was.
    Thanks for all the replies fellas.
    Cheers, Pete.
    re. the battery swap...Well done!!always pays to try the simple fixes first... A near flat battery causes all sorts of schizophrenic reactions in the P38
    thnx for the reminder!
    Oct 2007
    Pic as promised!
    Here is a pic of the new beast as promised, it's a big step up from my '89 Rangie...although I'm still working out what all the buttons do!
