Thread: Virtual Memory
    Virtual Memory
    I read it is suggested virtual memory should be set at 1.5 x ram. True/false ??
    Currently running Intel i7 CPU 860 @ 2.80 GHz 2.93 GHz 4.00 GB Ram on Win 7 x 64 bit
    Ta
    depends.
    I leave mine on auto manage and when the drive space is available it seems to hover around the 900MB-1GB mark on a machine with 512MB ram
    on the 1GB lappies its currently running at 2GB on one and zero on the other (tho the second one lives in a permanant minimum power usage state)
    I'd recommend auto-manage as well. The main thing is to have enough memory to prevent paging to virtual memory being a problem.
    Dave if you can put another 512MB of RAM in that PC you'd notice a big improvement.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    the formula was always 2.5 times your installed ram... auto managed swap files tend to fragment which can heavily impact a loaded system...
    esp *.nix boxes but good for most windows boxes as well
    there is a nice little utility for xp boxes called TuneXP oddly enough that helps set this and a couple of other useful settings with a mouse click or two
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    for what the machine does I dont really need it besides if the windows on it doest stop caffing me around its going to get the treatment and become a linux box and then 512mb would be more than enough hell I could probabley make it do what I need it to do on 512K
