Thread: front wheel bearing play
    Oct 2008
    bacchus marsh
    Question front wheel bearing play
    2002 defender how much is acceptable amount of play in the front wheels and how do i go about fixing it ??????
    thanks hans
    Feb 2005
    i would say zero, to adjust them is not difficult
    the free play could be in you swivel pins as well
    Castle Hill, Sydney, Australia
    I just adjusted mine. Do you want me to scan and send instructions? (85 County).
    Oct 2008
    bacchus marsh
    Smile
    Quote Originally Posted by Carslil Jim View Post
    that would be great
    thank you very much
    hans
    wont work unless the bearing setup has been converted from the spaced bearing with a stake nut to the traditional dual nuts with a lock tab washer.
    Its a td5/puma thing.
    No reusing stakenuts Hmmkay.....
    Kingston, Tassie, OZ.
    Like Dave says, in standard trim ALL Td5 Defenders were non adjustable - just tighten them up and peen over the locknut, so ANY play is a worry. As he also points out, someone may have converted to earlier set up, in which case they will need checking and readjusting.
    JC
    Hans,
    Since yours is a 2002 Defender I suspect the 85 instructions wont be useful.
    I think we need to establish what you have. I have attached two photos of mine. In the first photo I have removed the wheel and the little rubber (literally) hub cap.
    In next photo after removing the circlip on the end of the axle and the shims behind it (if any) I have taken out 5 bolts attaching the drive assembly...it just slips off the shaft. Now you can (almost) see two large nuts locked against each other with a lock plate inbetween that is bent over the nuts so they cannot move. The bearing adjustment is based on the inner nut.
    Apparently it is most likely you will see only one nut, in which case I have to hand over to more up to date experts.
    Dont forget to have a jackstand as well as a jack supporting the LR. No bricks. Large lumps of wood are good. One of my clan was among the first to drop a car on himself in the early 1900s. He died.
