Let's talk about Defender rear coil options
					I need to upgrade the rear coils on the Puma.  This is because the upper (progressive) coils sag under load - e.g. when towing.  Unladen the Defender is fine.
As I understand it the rear coils are a progressive 270-420 lbs/in (RKB101111).
I've decided not to go for polyairs or helper springs as I don't always have the weight in the back of the 110 and would like to keep a reasonable ride.  Whilst the Polyairs would assist I still need to replace the exisiting coils as the upper 3 coils (lower rated) are the issue.  I also don't want to lift the back with the suspension to higher than standard.
As I see it my options are to go for a heavier progressive or a straight liner replacement.
The HD LR springs (NRC6904/NRC6389) are a 330 lbs/in linear coil.
The OME 755's are also a linear (I believe) but only 270'ish lbs/in.
LRA can also supply a 270 lbs/in linear and a 320 lbs/in linear coil.
If the weekend's not to hot I was going to swap the King Springs KLRS-05's from the back of the Tdi to the Puma and see how they feel.  These are a heavy coil and I suspect over 330 lbs/in.  I can't find any publish rates for these springs.
The front end already has HD springs.  I'm also replacing the LR shocks with something solid - and expensive - Koni Raids.  So this will also assist the rear end as they should be  good under hot conditions.  They have a 70mm bore and I suspect will be unlikely to fade under normal track driving and make for a good ride on corrugations.
So I guess I have a few questions:
* If I replace the present 270-420 with a linear 270 I suspect this will be to weak for what I need.  Is this correct?
* Assuming I need a heavier rate spring then is the 330 lbs/in LR going to be too harsh when the Puma is unloaded?
* Are there any options I should also consider?
