Results 1 to 9 of 9
Thread: Help me clean my wheels!
    Jan 2009
    Does anyone know how to get these rust specs off the wheels? Guy at the dealer says it is pad dust and disc dust that has rusted, which seems to make sense as it is a rust brown when you scratch it off with a finger nail. It is very hard and well attached. I have tried detergent and spray on "wheel cleaner" but no go and the only way that works is to scratch it off with a fingernail, but is v slow and wore my fingers out. SWMBO won't help.
    Jun 2003
    Launceston, Tasmania
    Somewhere I think I had heard vinegar in some water worked.
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Quote Originally Posted by Phoenix View Post
    Also try "CLR"
    Oct 2008
    Cloncurry NWQ
    After you get them clean wax them.
    Stops stuff sticking to the wheels.
    Jonesfam
    Boxhead63 Guest
    Coca Cola...leave it on for 10mins then hose it off.
    Rob
    SA, Newton
    CLR
    any thing acid, but thats risky and needs time
    just use jif, then wax ( as already mentioned)
    and CLEAN THEM MORE OFTEN
    Up a hill in the deer park
    Sydney, Australia
    Oven cleaner works well.
    Anything caustic is a matter of timing if you leave it on too long it will eat into the clear coat though.
    Jun 2008
    I noticed that after several hundred k of gravell road the mags had a nice shine to them, not a speck of black brake dust to be seen, so problem solved, stay off the blacktop
    Ryall
