Results 1 to 8 of 8
Thread: Series rims onto discovery
    VIC
    Will the standard wheels off my 1960 SII go onto a D1? Should I use the standard disco steel wheel nuts to retain them?
    WA
    Quote Originally Posted by B92 8NW View Post
    Yes and Yes. Keep in mind your track will be slightly reduced which may not technically be 100% legal.
    Apr 2007
    Clifton Springs, Vic.
    Yes, but why would you?
    Aug 2008
    ...and don't forget to check what the load and speed ratings on the series tyres are.
    VIC
    Cheers Ben.
    As for why, one off emergency. They're crappy retreads, but I only need to get to the type store 20 km away.
    Near Seven Hills, Sydney
    Series 2/2a's had smaller stud holes than series 3 and beyond, so there is a chance they won't fit
    doable but not legal due to rim loading weights.
    driven sensibley it'll get you out of trouble.
    Brisneyland once again
    That's whats on mine at the moment, still waiting for the lads to find the correct wheels from mine.
