Volume = length x width x height
hey all, i've just bought an above ground pool which will be here this weekend.
the size of the pool is 7.8M x 5M x 1.8M deep. it's rectangular in shape.
can anybody work out how much water this pool will take in litres?
we are not connected to mains water so obviously live off a water tank. we have 2 dams which are pumped up to the house to do the retic. the water is a little dirty and smelly. if possible i'd like to fill the pool with this water.
is there a way of cleaning this water to use in the pool or could i even fill the pool and let the filters clean it or would this ruin anything
don't know if it makes a difference but the pool is a salt water pool.
One cubic metre of water is 1000 litres.
Most pools are 1.2m at the shallow end and 1.8m at the deep end. For calculation purposes 1.5m will be good enough.
So, your calculation would be 7.8m x 5m x 1.5m = 58.5 cubic metres
So, in round figures, your pool capacity is 60,000 litres which is a very common pool size.
As a tip, turn it into a salt water pool and always (repeat always) over filter it. That is, run the filter each day longer than the pool manufacturer's recommendations.
Then each month take a sample of water down to a (good) pool shop and do exactly what they tell you to do.
Happy and safe swimming.
Last edited by Mellow Yellow; 25th November 2009 at 09:16 PM. Reason: "cm" confusing: changed to "cubic metres"
Mellow Yellow
No matter what the problem - there's a solution. You've just got to find it.
2013 Discovery 4 TDV6 3.0
2015 Defender 90 - The TARDIS (Gone)
2003 Defender 110 - The Yellow Peril (Gone but remembered fondly)
2001 Discovery II TD5 (Gone)
1986 County V8 (Gone)
A yacht is considered a hole in water into which you throw money, never to be seen again. I have had a swimming pool. It is a hole in the ground into which you throw money. You have the good type of pool . Above ground. You can easily get rid of the bastard of a thing when your family's interest wanes. Usually when the kids hit fifteen or so and don't want to socialise with parents or stay at home.
You will learn (or re-learn) fitting skills. Pools have pumps and filters that need constant attention.
URSUSMAJOR
70200Lm aproximately.
Swimming Pool Water Volume Calculation
and
http://www.havuz.org/pool-calculators.htm
because its also got a basic chemical quantity calculator in it.
Which comes to 70.2 cubic metres or 70,200 litres.
... or 187,200 cans of beer![]()
dam water will be fine, just use plenty of chlorine and filter it until clear![]()
