Thread: Aschroft CDL Kit
    Mar 2007
    Tarneit VIC
    Aschroft CDL Kit
    In the process of installting the CDL kit from ashcroft. Bolted the two bolts on on the spigot plate and also nylock nut to spigot.
    Start the car and engage the diff lock but there is no diff lock light come up. Read this thread as it has the same problem and it was the the dog clutch in the transfer box sticking.
    what is the dog clutch and how do I fix it? or any other thing that I should check?
    Sorry for stupid questions but I am not really a mechanic. Thanks in advance.
    Read through the 'cdl' section in the 'Good Oil'. There is probably (almost certainly) nothing wrong with your cdl
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Ean Austral Guest
    Quote Originally Posted by dearot View Post
    Engage the diff lock, then jack up any wheel and rotate it and it should come on, with the ignition on so the dash lights are lit-up.
    Cheers Ean
    Mar 2007
    Tarneit VIC
    Quote Originally Posted by Ean Austral View Post
    Cheers Ean
    Yes I can see the light on now. Thanks Ean.
    Now time to put everything back. What size of rivet do I need?
    3/16 or 4.8 mm dia pops by about 5mm long.........but
    Even better is using speed clips and screws, makes it easy to dis-assemble next time.
    Mar 2007
    Tarneit VIC
    Quote Originally Posted by Urban Panzer View Post
    What's speed clips?
    Its too late anyway. Put evrything back except the console. Hope didn't forgot anything.
    Driving without the centre console at moment.Mrs complained abit on the way to friend place.
    A little bit noise without the console.
    May 2003
    On The Road
    just think "This must be what its like to drive a Defender"
    as with all things in life,,
    the CDL is
    USE IT
    or LOSE IT
    they tend to get a bit sticky when left for long periods---
    Speed clips, erm, like what holds your wheel arch liners to the factory bumper, indicator lenses to the wing on pre facelfit models......etc etc etc
    Know what I mean now ?
    Mar 2007
    Tarneit VIC
    the CDL is
    USE IT
    or LOSE IT
    you are right
    Mar 2007
    Tarneit VIC
    Yes I know what you mean.
    Wondering where I can get some of those here in Melbourne?
