Results 1 to 10 of 20
Thread: Replacement Key
    Gladstone Qld
    Replacement Key
    Hi All, lost my spare key for my "02" Disco and was wondering if landrover is the only place to get a replacement? I'm too scared to even ask how much LR charges!!!!
    Cheers.
    Jun 2008
    McMinns Lagoon NT
    There are a couple of previous threads that give a few suggestions. I ended up getting one of a private seller in the UK off ebay.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    May 2008
    Mudgeeraba, QLD.
    Hi Ted2910,
    I have just ordered new key from Ebay England. Approx $174.00 delivered.
    Try this site :
    LAND ROVER DISCOVERY 2 TD5 & V8 ALARM KEY FOB & KEY on eBay (end time 21-Dec-09 14:34:31 GMT)
    Dave.
    May 2009
    Central Coast NSW
    disco 2 key
    Once you have got the blank key how do you get it programmed to work your particular vehicle ?? I have purchased 2nd hand and don't have the key number??
    Croc
    Gold Coast, Qld.
    hey guys
    Was just at a Gold Coast Land Rover dealer today to get a new remote coded. Found out that the one I have is the incorrect frequency => therefore not compatible. Need to ensure you purchase one that is the correct frequency or risk doing your money. Was quoted @ $315 + $77 for coding!!! 2x new keys & it starts adding up!
    Has anyone had any luck with other options?
    Bullets
    Nov 2008
    on the move
    Can you program with the Nanocom to use the key manually?
    IE; unlock the door manually and disable the alarm, then be able to start the car without pushing the button on the key????????
    I seem to recall there is something in the menu about keys and such.
    Cheers Lionel
    Dec 2009
    Ranelagh, Tasmania
    eBay Australia Shop - DLS LAND ROVER SPARES UK: Chassis Body, Engine Gearbox, Tools and Consumables
    This guy has the european key in his shop but he also stocks the Australian 315mhz key (88 pounds)and will ship to Australia for 10 pounds.
    May 2003
    On The Road
    Hey Lionel
    Why not look in The Good Oil???
    phuma Guest
    use a second-hand key!
    I only got one key when I bought my second-hand Disco 2. I got a second-hand key fob from a guy who rolled his Disco. The key part (the shiny bit!) can be taken out, and you can just have normal key cut; with some filing and drilling you can then fabricate something that will fit into your second-hand fob.
    Once you've opened the key fob you'll see that there are numbers printed on a piece of paper sticking to the circuit board. Somebody with an autologic / nanocom can then use those numbers to "pair" the key fob with your Disco's ECU.
    Douglas Park, NSW
    Quote Originally Posted by Geedublya View Post
    Early D2s in Oz were 315MHz, then they changed to 415MHz. If in doubt, check with a dealer who can tell you what was fitted to your car originally. As a general rule, only the 99MYs had the 315 system.
