Results 1 to 6 of 6
Thread: Overdrive options
    Mar 2009
    Brisbane, Australia
    Overdrive options
    Hello,
    Have been searching for an overdrive for a while to fit my S3. Have finally found a bloke with two overdrives to sell. One a Toro (i think) and one a Fairey. They both spin easily although the Toro one spins more freely. Both come with the respective transfer gears to connect with the transfer case.
    I am aware that the Toro is supposedly the superior unit (bigger sump etc), however parts would be more difficult to obtain than the Fairey unit.
    The one I choose comes with a Fairey Linkage (the bit that goes into the cab to engage the OD). Will the linkage made for the Fairey fit the Toro?
    Which one should I buy?
    Both are the same price. I can only afford one.
    Any help is appreciated.
    Thankyou
    Cameron
    Hay Point
    Cameron,
    The Toro unit is definitely the superior one. I would buy it if it is ok. Pretty sure the Fairey lever and linkage is the same......Brian
    Toro - parts are problematic, but you should never need any.
    Northern NSW
    I have a S3 with a Fairy I always worry about running out of oil I've thought about making a spacer where the end cap bolts on so it would take another cup of oil does anyone have thoughts My other one has a rocky mountain unit which is real good as it uses oil from the trans case.
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by cammac91 View Post
    Hello,
    Have been searching for an overdrive for a while to fit my S3. Have finally found a bloke with two overdrives to sell. One a Toro (i think) and one a Fairey. <snip>
    Cameron
    My order of preference is always:
    1. Roverdrive (Rocky Mountain)
    2. Toro
    3. Fairey
    with 3. Fairey almost dropped off the list. (would never buy another one)
    Quote Originally Posted by will d8r View Post
    I have a S3 with a Fairy I always worry about running out of oil I've thought about making a spacer where the end cap bolts on so it would take another cup of oil does anyone have thoughts <snip>
    I have a friend who made a modification to his where he put a little metal funnel in the transfer box connected to fittings and a pipe into the side of the overdrive this creates a gravity feed circulation system similar to the Roverdrive. If the top of the funnel is just above the "full" height of the overdrive, you then never have to worry about running our of oil again.
    Diana
    I have a friend who made a modification to his where he put a little metal funnel in the transfer box connected to fittings and a pipe into the side of the overdrive this creates a gravity feed circulation system similar to the Roverdrive. If the top of the funnel is just above the "full" height of the overdrive, you then never have to worry about running our of oil again. Diana
    I wonder why Fairy did basically this for their LT95 overdrive but never did it to the series O/D. With the LT95 the transfer case will run out of oil before the O/D (but only just before).
