Thread: How do i clean the ECU
    Oct 2008
    I have read most of the threads re the ECU and oil in the injector harness, which i now have a issue with, my question is can or has anyone tried to clean the ECU with CRC's CO CONTACT CLEANER ?, it is designed for precision electronic equipment and computers, as i am having a new harness fitted in a few days i thought i would ask around for advise, the alternitive is to let it drain over night but it would still have an oily residue on the circute board.
    regards simon
    Adelaide - Torrens Park
    There should not be any oil inside the ECU, it is a sealed unit.
    Use th CO cleaner to clean the external plugs if there is oil present.
    Manly QLD
    It is possible – although not common to have oil in the ECU, mine had so much it was dripping out (so much for the sealed theory). If your harness is really bad it will capillary in through the pins, but you will have a lot of oil at the plug.
    Urban Panzer has a thread (I think it was him) on cleaning this, see if I can find it.
    Manly QLD
    With pics and all...
    Good write up by Mr Panzer - this is the same as what I had some moons ago.
    www.discovery2.co.uk / Workshop /Injector Harness
    Oct 2008
    Many thanks for the quick responce, and a very good link to the workshop page.
    simon
