Results 1 to 10 of 28
Thread: Towing
    Aug 2009
    South Australia
    Towing
    I have an 04 Disco 2 TD5 auto.
    Not having towed before with a LR, I'm aiming to tow an approx 1 tonne van. Now I know there's no problem with the weight, just wondering what the recommended gear is for towing. Just leave it in Drive, or hold it in 3rd? Up to 100kph, mostly good roads but some fairly steep hills. Ta muchly.
    Mar 2009
    Port Stephens N.S.W
    That'll be fine ... (Drive, that is), however, if your using cruise (or not) best to downshift to 3rd far enough before the bigger hills so the transmission has a chance to get 3rd locked up before you're going up the hill ... cruise is reactive, not pro-active ... so by the time cruise starts to gas on, you've lost too much momentum going up the bigger hills, and it will want to kick down 1 or 2 gears and rev its tits off trying to maintain road speed ... Drive (4th) is an overdrive at about 0.74:1, whereas 3rd is a 1:1 ratio.
    Kev..
    what he said with the following caveat.
    if its over a ton over tare mass and its around town or on hills lock it in 3rd.
    99.87 MB
    1t isnt much on the back of a D2.
    What works even better is towing with the transmission in sports mode. It wont hang onto gears as long before shifting into a lower gear and you don't have to think about manually shifting.
    Slunnie
    mousie Guest
    I'm 1.4t Swan Outback and I just drive normally and agree on the above cruise control. It has become natural for me to get to 82klm then off the throttle to allow the lock and then apply the load again and off to the 100 mark.
    You will get used to how much torque is available from the above technique without kicking back to third. Cheers
    Skellz Guest
    I have a 2002 TD5 and my cruise control will not work if I am towing is that normal. When I am not towing it works fine
    And a chipped Td5 is better again. It adds a whole new layer of functionality. More power, more torque and it will give you the ability to stay locked in 4th longer without hunting for a gear or undue labouring of the engine.
    99.87 MB
    Quote Originally Posted by Skellz View Post
    Thats not normal.
    Quote Originally Posted by feral View Post
    Actually yeah! I find that too. The chips make them want to hang on to gears too much.
    Slunnie
    au
    Thats how I drive mine with our Jayco Swan (onroad) on the back which is about 1T. I leave it in normal while on the flats and moderate hills that I know it will climb in 4th LU but when its a winding rd, lots of hills or big climbs I put it in sport mode. I was shifting it back to 3rd and getting it to LU but I find sport mode works just as well.
    Dec 2008
    Riverton W.A.
    Autos
    I tow a two tonne van and have just had the gearbox overhauled
    214,000 kays. The converter was stuffed!!
    Was told by the ZF service blokes in no uncertain terms when going up a steep hill drop back to third and use that lockup. Do not leave it in fourth. Been told that third l/up is in the box and fourth l/up is in the torque converter and it over heats if worked to hard.
    My light never came on.
    If you listen closely in sport all the four gears and overdrive are being used. At least thats what it sound like.
    Don't forget the van is 2 tonne.
    Tony
    Jees now there is two of me
