Results 1 to 10 of 25
Thread: TD5 Smoke screen
    Singleton NSW
    Exclamation TD5 Smoke screen
    I need help!
    Every time I drive my Disco 2a td5 in the same spot after driving along at 100 kph and lifting off the accelerator the engine totally looses power and produces a huge black unburnt diesel smoke screen behind me.
    Can someone help with a diagnosis for this?
    collapsing intercooler hoses.
    Aug 2008
    Since it happens when you lift off the accelerator after cruising along at speed, I would be thinking about the airflow.
    The turbo hoses maybe delaminating inside and blocking the airflow as you slow, thus black smoke.
    Undo the hoses to turbo, starting with the intercooler to intake one at the top and take a look inside.
    Edit: Damn phone interrupting my typing!
    Singleton NSW
    Thanks for that - is the solution to replace with LR hoses or is there something better?
    Aug 2008
    Quote Originally Posted by Daniel View Post
    LR rubber hoses are fine, but an upgrade would be to silicone ones that last longer and can hold pressure better.
    Usually cost a bit more though, but rubber ones from LR can be costly too.
    Singleton NSW
    Thank you for your advice.
    I've pulled the hoses off and the turbo to intercooler hose had a huge bubble inside almost totally blocking the duct. I guess when it heats up it stretches so much that it totally blocks the air flow and hence the motors stops.
    Who is a good supplier of silicone replants?
    Padstow NSW
    go to the bell auto services web site, you can get them here in a week from the UK, for the initial outlay you will never have to replace them. there are lots of ppl on here running them.
    cheers phil
    try tombie2.
    Singleton NSW
    try tombie2.
    "tombie2" - what is that?
    Padstow NSW
    it equals bell auto services.
    tombie2 is a forum member, he dosnt have any in stock and get his from BAS.
    cheers phil
