Results 1 to 9 of 9
Thread: Defender Calipers
    Adelaide - Torrens Park
    Defender Calipers
    I am in the process (long and slow) of rebuilding a Holden Ute (W.
    One of the jobs I am doing is upgrading the standard braking system.
    I am converting to 4 wheel discs and I want to go to a larger disc and better calipers.
    I have seen conversion kits for sale that use twin piston calipers (sliding), but I really want four piston calipers. I enquired how much a four piston caliper setup would cost and it was going to add about $1000 to the cost!
    My question is, if I get the hub and disc setup with no calipers, do you think the Defender calipers would be up to the task? My gut feeling is they would be fine, provided I had the correct bore in the master cylinder. I would just need to make (or have made) an adaptor plate to bolt the calipers to the hub upright.
    The WB master cylinder is a 1 inch bore, what does a Defender use?
    Or maybe I can use Disco I calipers? I have a set of them...
    Safety Bay
    It's a Holden ute BigJon,it can't be that hard.There must be a holden model that has what you need,I'd read some street machine mags and find out what those guys use. Pat
    There are common aftermarket conversions using single or twin piston sliding calipers, but I want to use four piston calipers. I have Disco calipers in the shed, so it would make sense to use them (cheaper).
    malrv1 Guest
    The Valiant blokes use Landcruiser or Hilux calipers and they are almost bolt on. later Valiants used the PBR calipers the same as Holdens so you might find the Toyota calipers go close to your Holden as well.
    Hi,
    Google Hoppers Stoppers (in Vic). The upgrade you seek is their daily business.
    cheers, DL
    Quote Originally Posted by 350RRC View Post
    Hi,
    cheers, DL
    Yes, but the prices they charge aren't my daily business!!
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by BigJon View Post
    Prices are steep, Castlemaine rod shop also do brackets to mount commonwhore calipers which you can find in 4 piston variety to holden HQ to WB stubs. I have a 1958 FC sedan with HR front with hq stubs and VN commo rotors/ hq calipers (although looking at commo as well ) a VB salisbury diff with VN disc brake setup. The VN rears will suit your holden diff as they all share the same brake bracket mounts from EH to WB.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Hi,
    It was only a suggestion so you might be able to see what they do for your POS as a bolt on. Where you source the parts and at what cost would be up to your likely considerable expertise.
    cheers, DL
