Results 1 to 6 of 6
Thread: Clunk noise on reverse
    Mar 2007
    Tarneit VIC
    Clunk noise got worse when putting the gear no reverse (auto gearbox) yesterday. Always heard the noise but yesterday got worse only. This morning wasnt so bad.
    Is this normal? Is it time to change the automatic gearbox oil?
    richard4u2 Guest
    with the wagon on flat ground and in netural and hand brake off get under the wagon and turn the prop sharfts back and forth a little and see if either have a lot more movement then the other
    Time for a very CLOSE inspection of the propshaft UJ's imo, in particular the front UJ's in the hookes joint (double joint)
    Jan 2008
    ACT
    Probably the UJ's - mine was teh same problem and became a "tweet" noise also. Purchased two greasable UJ's from a bearing speclialist for less than $50 - a Hardies product I beleive?
    Fitted by a mechanic or can be done yourself is you have the gear..
    Mar 2007
    Tarneit VIC
    Thanks guys. I will check this weekend.
    99.87 MB
    It may also be lash in one or more of the centre or axle diffs.
    Slunnie
