congratulations on the arrival of your new babies...
should work a treat up you way
Mrs ho har
No not Dave's old Landy
But there's four of them and they are big and they are definitely red.
No these are big red 90 series Koni Raid Dampers for the Puma. Stolen from Santa's sleigh. They weigh about 6kg's each. That's a 50c piece on the top of one of them to give you an idea of the diameter. When I go to swap them over on the weekend I'll take a piccy with them next to the OEM one's.
I suspect getting to the front shock towers on the Puma may be a little frustrating
Mrs ho har
Series Landy Rescue
Our FB Page..
Shiny..... for now. They are very nice. Man santa's gonna be very unhappy.
6kgs each man that is heavy
I look forward to the road test DM.
If the weather holds I'll put them in on Saturday. Though if it's as hot as last Saturday I'll probably just stay inside with the A/C.
Will followup with more when I get them in.
Noice Derek!
Don't forget to test them thoroughly
JC
Watch the bolts that hold the towers on.. they are soft and strip easily
 2005 Defender 110
What else would Santa bring when additional camera equipment has been outlawed?
Cheers, Dale
'The D3' - 2006 TDV6 HSE
Previously Enjoyed:
2000 D2 Td5 - plus!
Yep, know about that form the Tdi. Puma looks to be exactly the same. Bigger problem is going to be extracting the shock tower out through the engine bay. Some idiot designed it with hoses in the road. It looks like I'll have to remove the air filter and plug up the air intake hose with it tied back to something.
