Results 1 to 3 of 3
Thread: fender air-con leaking
    Nov 2008
    well we all no that a defenders a/c isent the best in the world even on the normaly hot days, so we allway have it on coldest setting,,
    so its working over time to try keep cold,, iv just had my a/c out of my fender and cleaned it all and made sure the drain it sealed and not blocked, but what can i do to stop the a/c pipes stop freazing up and driping on the pass floor,
    has any one come up with a good idear to stop it,
    aircon fix
    In my trayback if the fan setting is not high enough with the air con set to max it will do the same thing. Ensure the pax is not pinching the drain with a foot or the floor mat.
    My aircon guru indicates the max setting should not be used all the time as it does not allow for condensate to melt and drain through cycling. Try adjusting the temp to just off the max stop.
    gold coast
    had problem with mine lately, working when it wanted to not when I wanted it to, found the little black box the wires go into in the battery compartment were not connecting properly so took out said little black box and on the bottom of it is a thermostat temperature control that overrides the one on the dash, maybe it can be adjusted to give a cooler setting, will try to post a pic tomorrow to show what i mean, the wires needed a jiggle a few times to clean the contacts so it would work all the time, must have been some dirt on them.
