Results 1 to 10 of 22
Thread: Oil Filter Tool
    Ean Austral Guest
    Oil Filter Tool
    Gday All,
    Im sure this has been covered, but how do people tighten the oil filter on the td5 engine....Yes that wonderful one behind the turbo.
    Been looking for a suitable tool but had no luck yet..
    Thanks and Cheers Ean
    Couple of things to try:
    Large cable tie.
    Kincrome (and others) make a webbing strap tool that you wrap around and tighten. Should be able to get one from any auto parts place.
    http://www.kincrome.com.au/web/catal...number=K080005
    Remember it doesn't have to be done up very tight.
    Bacchus Marsh Vic.
    I have been knowen to "tap" the top rolled section of the filter with a blunt screwdriver.
    BUT BE GENTLE, a bit like doing wheel bearings without the right spanner.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Williams West Aust
    Somebody on here posted the perfect method the other week.Piece of soft cord wound around the filter twice.Hold both ends and pull to undo.
    Havent tried it,sounded so simple.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Shepparton
    Filter pliers - go get a set NOW, beats all other methods hands down.
    Ean Austral Guest
    Quote Originally Posted by crash View Post
    Are these the same as the one's for sale at supercheap.?
    Filter pliers are basically a really, really wide opening adjustable pliers. They may fit in the limited space of the Td5's engine bay.
    Brisbane, Inner East.
    Hammer a screwdriver through the filter and turn the filter with the handle. I have used this old trick on a number of modern cars particularly the little oriental crappies with the tiny filters almost hidden from view or access.
    URSUSMAJOR
    I do the rope trick when I forget to bring the CAM action filter strap. The tool box is packed right now but If I remember at the next service I'll show up the pics and how to tetris your arms around the td5 to make it work well
    $10 from aldi for 2 in a blister pack.
    They also work like a charm for gripping shock absorbers.
    Yinnar South, Vic
    I use the strap type to do the same
