Results 1 to 10 of 12
Thread: Wheel Lock Nuts
    Wheel Lock Nuts
    Long story short, I went to take a wheel of the Disco this atfernoon, and found that some other kind person has been there before me and chewed the locking nut...
    So the big question is... what is the best wat to remove the nut now?\
    Any advice gladly accepted!
    Matt
    Williams West Aust
    You should be able to undo it with a hammer and punch,once its loose should be easy.
    Try member "Bundalene" (Erich) for a replacement,you will need the code letter.Erich wrecks D2s and is quite a helpfull chap.
    Goodluck
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    May 2003
    On The Road
    or do what others have done and throw the locknuts away----
    get a bi hex socket that only just doesnt fit on. Hammer it home and undo.
    Failing that die grind the nut off and then replace it. IF you nick the stud you have to replace the stud as well.
    Brisbane,some of the time.
    X2
    Get 4 new standard nuts from the wreckers for the road wheels & leave one locknut on the spare.
    Alloy wheels not stolen at all in AUS then ?
    Atleast you'll have the spare left !!!
    May 2003
    On The Road
    only by jealous BMW owners,,,
    Jun 2008
    McMinns Lagoon NT
    Quote Originally Posted by Urban Panzer View Post
    Yes.
    However I have not seen too many Commodores driving around on stolen Land Rover alloys fitted with muddies.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Jul 2007
    A few people had the wheel nuts stolen but not many that I know of have had the wheels taken. A bit different if it was a rice burner go fast car.
    Never heard of the road wheels being stolen.I would rather risk that happening than being stuck out in the bush somewhere & not being able to change a wheel.
    The security sockets have a habit of cracking which is a real PITA
