Results 1 to 10 of 21
Thread: Nanocom and Window's 7
    Ean Austral Guest
    Gday All,
    Not being really good on the Confuser it may be a operator error but am having no luck being able to install the Nanocom drivers on the new laptop with windows 7.
    Can load the program and the pdf files but not the drivers to link the nanocom to a com port.
    Any help would be great.
    Thanks and Cheers Ean
    You may not need the drivers Ean.
    I'm assuming the Nanocom uses a USB to serial convertor on the laptop in which case have you tried just plugging the device in?
    I'm not familiar with Windows 7 so that's about all the advice I can give.
    Ean Austral Guest
    Thanks Derek,
    I thought the same thing, but when you want to use it with the laptop it tell you to link the com port and to do that it says you need to install the drivers.
    Will get the 15 y/o to look at it when she gets home.
    Hope you had a great christmas.
    OK, what is the cable that you link the Nanocom to the computer with? I'm assuming this is a USB to serial cable.
    Does it have a name and model number on it? If so you can probably locate the driver(s) from the manufacturers site.
    Of course 15 y.o.'s are much more computer saveey than our generation so it may be quicker to wait her arrival.
    Christmas was nice and slow and an incredibly hot day. Didn't go out bush for lunch but waited until the evening. Got rid of a box of those rather big Tigers, BBQ'd down the beach that evening. Very tasty and can't wait to do some more - probably tomorrow night.
    Ean Austral Guest
    Gday Derek,
    the cable came with the nanocom unit so it has no # or anything on it but it fits the nanocom and has a USB on the other end, so I just assumed its the right cable, but the disc does say XP or Vista so maybe it doesnt recognise windows 7.
    Made the mistake of eating some farmed prawns at a Chrissy lunch we went to, but redeemed myself boxing day with a big seafood cook-up.
    Cheers Ean
    Dalby
    You will need to get on their website and download the Win7 drivers.
    May 2008
    Mudgeeraba, QLD.
    Hi Ean,
    I have nanocom software on my laptop running under Windows 7.
    I think you need power to your unit before windows will recognise it.
    So just plug it into the 240 volt and connect it to your laptop. Should be automatic from there. Make sure nanocom CD is in your CD drive.
    Dave.
    Ean Austral Guest
    Quote Originally Posted by DavidB View Post
    Hi Ean,
    Dave.
    Gday Dave,
    I trtied that, several times, it keeps telling me that the drivers wont load.
    The actual Nanocom loads, but I cant get it to link to the com ports.
    Think its possible its something im doing wrong,but I would have thought the computer would recognise it and load it automatically.
    Will keep trying
    Thanks Ean
    May 2008
    Mudgeeraba, QLD.
    Ean,
    I suggest you reinstall the Nanocom software. Just put the installation CD into your CD/DVD drive.
    You should be asked to Repair or uninstall Nanocom. Choose Repair.
    This should reinstall your driver.
    To check this Connect your Nanocom to power then connect it to your laptop.
    Now open Control Panel ( Click Start then Control Panel). Now click on Hardware and Sound. Then click on Device Manager Devices And Printers.
    Look down until you see Ports (COM & LPT). Click on the triangle before it and you should then
    Nanocom diagnostit tool. Refer attached picture.
    Hope this helps.
    Dave.
    Attached Files Attached Files
    Ean Austral Guest
    Gday Dave,
    I gave up before I smashed it, I have tried what you said,I also removed the program, un-installed the driver and tried to reload, but it still wont accept the driver.
    I evan tried to download a driver from the nanocom website, but it just tells me its a compressed file and the computer wont open it.
    It loaded onto my office computer on windows xp first go..
    F I I K,
    will keep trying.
    Thanks for your help,
    Cheers Ean
