3.0 D4 RF height sensor wiring PM
I found the wiring harness from the right front height sensor where it is attached to the top of the chassis rail was rubbing against the sharp edge of a bracket that appears to be for a heat shield for the RH turbo. A little twisting-up of the bracket's lower edge has given good clearance and a rounded edge to the wiring which should prevent chafing.
