Results 1 to 10 of 22
Thread: Oh' to set up a Disco 2 for outback touring?
    May 2008
    Lower Hunter Valley
    I am pondering the usual must haves for setting up my 2002 TD5 Auto for 6 week jaunts into our lesser known regions of aussies interior.The vehicle is well maintained with low kilometres.
    The obvious add ons of winch/winch bar, snorkel,UHF radio,additional transmission oil cooler (towing a camper trlr)and my biggest concern is the lack of the centre diff lock. The actation rod in the transfere case has been replaced with a blank housing with no sign of the centre diff lock.
    Ive thought of ARB lockers But there very expensive.There must be a better way,the landrover way. How about replacing the transfere case with a diff lock model? What probs to encounter with the Traction Control in the vehicle.
    As may be obvious your thoughts appreciated!
    Williams West Aust
    You need the early or late D2 transfercase.Traction control works VERY well with the CDL locked.Soft beach sand is OK as long as you have aired down,if not the TC will do its best to bury you.
    A nanocom or similar plus a RAVE CD(workshop manual on CD) are a must,plus the ability to work and understand the nanocom.
    ENJOY
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Brisbane,some of the time.
    Had the model without the CDL for a while & didn't have any problems,but with CDL is definitely better.If you are not doing any VERY tough 4WDing,i would leave it as is & spend the money elsewhere.
    You have the winch if you really get into trouble.
    Std transmission cooler is fine if its not full of mud in the fins!
    Retrofit the CDL gear into the TC
    The other gear on your list is good.
    2" lift
    EGR removal + Mild tune upgrade.
    Kingston, Tassie, OZ.
    DO NOT skimp on suspension. Plenty of good real world advice and testimonials from users here on whats best for what on their D2's.
    Personally I have had good results with Bilstein shocks and LRA springs, but there are plenty of other packages, just choose quality components.
    $$$ spent in this department is a good safety and reliability tip
    JC
    Fit a greaseable DC joint on the front prop shaft - or am I being paranoid from a bad experience.
    Consider a good hand winch over an electric winch but still carry a snatch block and other recovery gear. Also make sure you have front and rear recovery points fitted (Troutbeck sell front recovery eye plates) and a tow hitch recovery receiver is good value to carry for the rear.
    Like JC mentioned don't skimp on suspension.
    You may find the ARB lockers aren't as expensive as getting a CDL transfer case.
    I'd also get a larger intercooler as this will improve things in hot weather.
    Carry two jack stands - one for the car, one for trailer. I realised this mistake when I had to use it under the trailer at the camp site and drove out for the day thinking "I hope I don't need that!"
    Carry a spare jack.
    Flush your entire windscreen washer system until it is only clean water, this gives you about 9L of drinking water in an emergency.
    May 2008
    Lower Hunter Valley
    Thanks Tombie2
    the local LR workshop push the additional trans cooler very hard,they tee off original lines & fitt an additional cooler.
    2'' lift lift good I have SLS (recent new airbags)
    What, mild tune upgrade, is this via electronics??
    May 2008
    Lower Hunter Valley
    Thanks to all for your time.I know this is decision time that we all debate about around the gas stove. I'm trying to wade through the real valuable items & not get caught up in the fluffy rubbish out there I dont need.
    To keep SLS or go full coils?? Argh another dilema!
    Cheers to all
    Apr 2007
    Prospect SA
    Plenty of cars without a CDL have made it but it does give some more piece of mind.
    Rear diff lock also makes a big difference.
    Also pack spare hoses and belts, snatch strap, pressure gauge, hammer, spanners, 2 rolls of heavy duty tape, air jack, long shovel, matches and matches and flushing windscreen washer reservoir is brilliant idea.
    Check the exhaust and all bolts with suspension, they be first to get loose.
    Take spare wheel nuts too and spare fuses.
    Don't forget the ipod, outback touring can be a bit bland.
    Happy touring.
    johnclv Guest
    Get a Sat phone and have the numbers of your LR mechanic handy. It was the most used "tool" in my tool box when trying to take my D2 around OZ
