 Originally Posted by
BilboBoggles
				I've noticed that the Clutch on my TD5 Defender is biting quite high on the pedal, compared to the new PUMA's Clutch.  I'm not sure if it's jsut that I've forgotten where the clutch bites or if it's telling me something.   For example I only have to push  TD5 pedal a very short way before it disengages, wheras the PUMA needs to go nearly to  floor.   The TD5's clutch is not slipping, and otherwise drives fine.  It does have 170,000k's on it though.  I always thought that the hydraulic clutch would self adjust until there was no more friction material, and then slip.  Can it also move it's grab point as it wears?
So what do you think?
 Yes the friction point can move higher as the clutch wears, BUT the pedal heigt and pushrod length can all be adjusted in the 110/ 90 etc. Basically, check that the clutch pedal inside is roughly level with the brake pedal, adjust it using the stop screw on the pedal box.Then you need to remove the top cover of the clutch master cyl pedal box and check if the pushrod is actually unloaded, IE it must not be pressing hard on the master cylinder piston. Adjust it from up top so it has freeplay at the pedal of about 5 to 10mm at the pedal pad before it starts to push the piston in the master cyl. If the clutch is still engaging right at the top then it is worn. If not slipping however, keep driving. Bear in mind that a flywheel replacement is on the cards if the clutch does start to slip as they can't be machined in the Td5.
JC
