Results 1 to 10 of 11
Thread: Fuel filter light
    crl Guest
    Fuel filter light
    My fuel filter light is flashing occasionally indicating water in the fuel and has done so for a few tanks of fuel now. Is there a sediment bowl that I can check to drain water from? I thought maybe the sensor needed to be looked at, where would I find the sensor?
    The vehicle is a 2000 D2 TD5 Auto.
    crl
    Dec 2008
    Beechboro Perth
    Quote Originally Posted by crl View Post
    crl
    The sensor is on the bottom of the fuel filter (located behind the R/H rear wheel) I suggest you remove the wiring plug from the sensor ( push the metal clip in) & check that theres no water or dust in the connection & if thats ok undo the sensor & drain some fuel out of the filter & see if theres any water in it.
    Regards Roger
    Williams West Aust
    The light is a waste of time.
    They dont work,mine flickers on right hand bends at a certain level in the tank,2/3rds from memory.
    As far as I know it was deleted on the D2a's.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Mar 2009
    Port Stephens N.S.W
    My 04 D2a has the sensor attached to the fuel filter ... but the cable ain't nowhere to be seen (well, it is tucked up high and pushed forward where you can't easily see it).
    Obviously, disconnected and relevant computer told to disable that system.
    Kev..
    crl Guest
    Quote Originally Posted by Disco W.A View Post
    Regards Roger
    I took your advice this afternoon and followed the above instructions. Didn't seem to be water in there as best as I could tell but I cleaned the connections on the sensor so we will see how it goes.
    crl
    May 2008
    Horsley Park, Sydney
    I think these indicators are a good idea. Where our daughter lives in the tropics, and filling up from 44's quite often, they have to drain the filter far more often than we do. The trick is to ignore the light if it flicks on occasionally but act if it stays on for any length of time.
    I retrofitted one to out 06 Defender and this occasionally flashes on - tells us it is still working.
    Erich
    crl Guest
    Quote Originally Posted by Bundalene View Post
    Erich
    Tells us it's still working - I like that explanation.
    Zute Guest
    On ours,(2001) we find the light will come on more often when we buy fuel from one particular service station. And also as we get nearer to an oil change. Though I never find any moisture in it when I inspect it.
    Malanda FNQ
    Thumbs up fuel water indicator
    Change the fuel filter. I drained mine --no water tospeak of--changed filter and cleaned elec connections wd40 and lanoguard all ok since
    crl Guest
    Quote Originally Posted by greg smith View Post
    I'm due for a service soon so it'll get changed then and I'll see what that does.
