Results 1 to 10 of 16
Thread: Mystery bolt
    Eidsvold QLD
    Mystery bolt
    Had the sump off the Defender today checking the Oil pump bolt and all was well BUT any ideas where the M6 x 25 bolt that I found in the sump may have come from??? Nothing obvious missing from underneath, maybe its a spare?
    May 2009
    Tatura, Vic
    Some engines have a support bracket for the oil pick up. Have you looked there?
    Dave.
    Eidsvold QLD
    Quote Originally Posted by Mr Whippy View Post
    Dave.
    nothing missing there.
    Bacchus Marsh Vic.
    Wonder if it's been there from new?
    If the sumps still off have look between the timing chain for the lubrication jet and bolt.
    The bolt head is below the jet outlet and around 60mm above the top of the bottom gear.
    Also check the lower "brace"/stiffener plate to block bolts are all there.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Jun 2007
    Well I will tell you a funny story. I was in the Land Rover factory watching a range rover sport being built. The worker had just put the front and rear suspension on to the car and he was waiting for the next vehicle when a bolt fell out of the car onto the ground, he looked to the left and to the right and then threw it into the bin. So you say you found a bolt in your sump, I am really not surprised
    Eidsvold QLD
    Quote Originally Posted by alien d2 View Post
    yeh, I sorta thought that might be the case, but being a Landy AND with the run of luck I've had with it lately I thought it more likely to be from a key component!
    Eidsvold QLD
    Quote Originally Posted by lro11 View Post
    forgot to mention I also found a Kipper and a cucumber sandwich!
    Jun 2007
    Quote Originally Posted by crump View Post
    Well you are lucky then I have a friend who worked at the rover car factory I bet you can't guess what they used to leave under the back seat of some of the cars (starts with s)
    Williams West Aust
    HIT
    Thats so wrong!!!!!
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Brisbane, Inner East.
    True Story. About 1960 a friend bought a new Morris Elite. In the boot was a square lump about 6" x 6" x 1" under the sound deadener and blue paint. At first service he asked the service dept. what it was as it was not shown in either the owner's handbook or sales literature. Dealer's staff had a look at others and were mystified. Eventually someone scraped off some paint and sound deadener to find a jam sandwich.
    URSUSMAJOR
