Thread: D2 Td5 and snorkel
    Aug 2009
    Athens - Greece
    D2 Td5 and snorkel
    I usualy make a research before i order something for my disco,this time i did the opposite.
    I ordered a mantec snorkel,but a (jealous maybe?) mate told me that with a snorkel - no matter what brand - i 'll lose performance (my disco i mean ).
    And here is the question,have you encountered a decrease in perfomance after fiting a snorkel?
    Tell me pleasee.. i am a newbie
    Thanks.
    May 2003
    On The Road
    Whatever small amount you'll lose by increasing the intake length, you'll get back by cooler air into the engine.
    Just make sure the connection from filterbox to snorkle is watertight!
    Nov 2008
    also a well positioned intake will "force" air into the air box, witch is all so cold air, and improves the air boxes flow rate
    but im prety sure when your going thru a river bonet deep the last thing your thinking about is perfomance
    NSW SW Slopes
    If you drive in dusty areas you will save the air filter from quickly getting clogged with dust.
    Malanda FNQ
    Talking snorkel orkel!!!?
    TELL your mate to start speaking from the mouth end. I have just fitted a snorkel to my 02 TD5 if anything better performance above all peace of mind air intake now not coming from within the wheel arch [check cainsboy in introductions]
    Brisbane,some of the time.
    Had the Safari snorkle fitted to the D2 a year or so ago & didn't notice any performance changes.
    What i did notice is the dust in the air filter is dramatically reduced in dusty conditions,& a lot less worries about deep water crossings.
    I am actually kicking myself as i should have had one fitted from new...
    SW coast, Victoria
    I self-fitted a Safari one within weeks of buying my new D2 in 2001.
    A bit scary thinking of hacking into the mudguard but was easy with the provided templates etc.
    Yes, make sure the join between the old underguard air intake and the new snorkel is well sealed. I must have used something like Sikaflex (polymer) and was very generous with it.
    Just recently I had to get a new windscreen and you guessed it ..the snorkel had to come off ( including drilling out the pop rivets from its mounting bracket on the A-pillar).... so that the A-pillar window trim could be removed for access to the glass.
    Cutting away the sikaflex with a blade knife took a while!!!
    I reckon the snorkel noticably reduces the dust in the air filter.
    Can't see it from the drivers seat so no view restriction.
    Bob
    Oct 2008
    victoria melbourn
    Quote Originally Posted by fatman View Post
    Thanks.
    i beleave myth busters did a test on this and they said you gain 7 % fuel economy. ill tell you what tho, ither way im keeping mine on !
    Malanda FNQ
    d2 td5 and snorkel
    Thanks.
    No ---but my engine runs with clean air at all times--I feel safe from dust[the engine killer]
    99.87 MB
    I think my performance reduced also with the Safari and Safari/Land Rover snorkels (they are the same apart from badging)
    Slunnie
