You didn't say wether rear plug was in the head or the block. steel welch plug at rear should be able to be replaced as mentioned by cutting a hole (hole saw) in bulkhead. If its the one that screws into the head I would take the head off as there are others hidden by the manifolds and a number along side the pushrods under the rocker cover these should be checked also. No point in fixing one if the others are about to go.
					 Weeping Rear Welch Plug
		 ). I've got by on the last trips using 'Bars Leaks'. Since the next trip is planned over to Lake Gairdner SA and has the potential to be hotter, I'm worried about the plug giving way when I least want it to.
				 I misread the 35 as 32.
