 Master
						Master
						Does anyone have a picture of where the handbrake return spring mounting point on the transfer case is?
Thanks, Peter
One end of the spring should be attached to the lever as in the previous post and the other should go to a similar bracket on the stud of the gearbox mounting plate on the gearbox.
 Master
						Master
						Thanks guys. Now all I have to do is root through the boxes of bits until I find the bracket - or else start to make one.
Peter
Last edited by Wolfman_TWP; 18th January 2010 at 07:35 PM. Reason: Opps, should have read 'clutch pedal'
